Author Topic: Icon Display on supported html model  (Read 3386 times)
tmaus
« on: February 08, 2005, 06:21:48 am »
we are exporting our project using the html exporting function.
our complete formal description resides in the "use case model" area.
i see problems regarding the created icons for each kind of diagramm.
use-cases, state-diagrams and at least state-diagrams do have the same icons which is definitely wrong as a viewer should be able to distinguish the kind of diagram based on the icon used.
is this a bug or a feature ????
Re: Icon Display on supported html model
« Reply #1 on: February 08, 2005, 06:34:17 am »
Shouldn't they recognize the type of diagram according to the contents? You could also use a naming convention (Axxx for activity, Uxxx for use case, Sxxx for state diagram)
« Last Edit: February 08, 2005, 06:34:36 am by thomaskilian »
tmaus
« Reply #2 on: February 08, 2005, 06:41:37 am »
it should recognize it by the type ...
but actually it does not ..
we could of course touch each activity- and statediagram ... but this is a lot of work ..
i hoped that we did a mistake .. but i really looks like ea produces the same icons for both of the diagrams
« Reply #3 on: February 08, 2005, 06:52:33 am »
EA produces 4 different icons one "general" and other ones for state, activity and sequence. You might use naming convention for all others if you wish.
tmaus
« Reply #4 on: February 08, 2005, 07:08:09 am »
thanks for your reply thomas ..
the following snipplet of the lower left frame provides the used icon to display both, the
use-case-diagram as well as the activity diagram
<tr>
   <td width="10%" class=ContentRow><IMG src="../images/diagram.gif"></td>
   <td width="90%" class=ContentRow><a href="EA3.htm" TARGET=content>098</a></td>
</tr> <tr>
   <td width="90%" class=ContentRow><a href="EA5.htm" TARGET=content>098: Default-Risikokomponenten initialisieren</a></td>
</tr>
we started to model a use-case ...
and created the corresponding activity diagram as a child of this use-case.
the child gets created in the same view-area (use case view )
if you are right .. which i assume you are ..
one of the icons should be displayed with a use-case diagram icon and the other with the activity-diagram icon ...
:O(
did you get my problem so far ???
« Reply #5 on: February 08, 2005, 07:22:22 am »
I see your problem. The HTML documenter does not generate different icons as the browser does - just one diagram icon. I guess you have to ask for an enhancement - or wait a day for Sparx to comment :-/
