Author Topic: Is it me, or something is wrong with build 747  (Read 3551 times)
igmand
  • You are unique… just like everybody else…
« on: February 15, 2005, 09:33:56 am »
Hey guys,
I've installed build 747, it looks good but...   all menu icons are wrong now... New diagram looks like "delete cross", Mentor icons are now look like operation icons and so on... Uninstalling/re-installing didn't help...
Any ideas? Is it a bug or feature?
Igor
« Last Edit: February 15, 2005, 09:34:44 am by igmand »
Gary W.
Re: Is it me, or something is wrong with build 747
« Reply #1 on: February 15, 2005, 03:32:00 pm »
If you mean 'right click on Project View', then no, the 'New Diagram' icon is still three boxes joined by associations;  the same as the icon at the top of the Project View.
I don't have Zicom Mentor so I cannot see your other example.
Actually, I was just going to post a similar question but it was '... is it me, or is Build 747 about 3x faster??' .   The response is so fast I thought there was something wrong with my machine... =8^)
gary
benc
« Reply #2 on: February 15, 2005, 04:17:36 pm »
Hi Igor,
It's a bug- to be corrected in the 748 release. The work around is simple enough :
Try : Tools | Customize | Tool Bars | Reset All
Alternatively :
Try : View | Visual Layouts | Default Layout.
I believe the problem is related to Mike's post here :
http://www.sparxsystems.com.au/cgi-bin/yabb/YaBB.pl?board=suggestions;action=display;num=1108481216
I'm curious - did you attempt to restore a user layout from an earlier version of EA, after installing 747?
Gary : As regards the speed factor : no particular performance enhancement comes to mind between 744 and 747 releases. Were you using EA over a network and got a faster link ...? There could be a number of reasons depending on what operation you are performing, but not specifically tied to 747 improvements ...
Ben
igmand
« Reply #3 on: February 15, 2005, 05:00:49 pm »
ok... it works.. :)
