Author Topic: interaction: start a message from a self message  (Read 2647 times)
tvdberg
« on: February 20, 2005, 11:10:22 pm »
This acctually are two problems.
First, starting a message from a self-message in an interaction diagram is valid UML? For me it is, but I do not know for sure.
Second, if it is valid UML, I do not seem to get it working in EA (version 4.00xxxx, build 725).
What I want to do is:
- Add an instance of class A to the diagram
- Add an instance of class B to the diagram
- Add a self-message for the instance of class A (for example init())
- Start a message from within the self-message to the instance of class B (for example connect())
EA places the created message under the self-message. That would indicate it would be started after the self-message is finished. I want it to start and finish within the self-message.
for example:
void A::tick()
   if(this->connection == NULL)
           this->init();
   doSomething();
void A::init()
   B::connect();
static void B::connect()
   /* connect to something */
Takeshi K
    • Sparx Systems Japan
Re: interaction: start a message from a self messa
« Reply #1 on: February 21, 2005, 12:24:35 am »
If I understand correctly what you mean,
please use 'Call' message instead of normal 'Message'
when you make 'connect()' from A to B.
Hope this helps,
t-kouno
t-kouno
tvdberg
« Reply #2 on: February 21, 2005, 12:35:52 am »
Yes, that did the trick. Thanks
