Author Topic: How to make Getters, Setters create implementation  (Read 3629 times)
Jeb.Beasley
« on: February 23, 2005, 04:32:46 am »
Lang C++
can I tweak the language templates to have the generated getters and setters provide the actual implementaions
I add an attribute, and specify that it is a property...
EA generates
COleDateTime CMyData::GetLast_Mod(){
void CMyData::SetLast_Mod(COleDateTime newVal){
How can I make it do
   return m_Last_Mod;
   m_Last_Mod = newVal;
Jeb
« Last Edit: February 23, 2005, 04:34:10 am by Jeb.Beasley »
Tryst
Re: How to make Getters, Setters create implementa
« Reply #1 on: February 23, 2005, 04:49:25 am »
You should check the boxes labelled, 'Read' and 'Write' in the 'Create Property Implementation' window.
Tryst
Tryst
Jeb.Beasley
« Reply #2 on: February 23, 2005, 05:03:23 am »
Yes, they are checked, it creates the function prototypes and implementation stubs, but does not create the internal assignment on the setter,  nor the return statement on the getter.
See the code above
tnx jeb
TrtnJohn
« Reply #3 on: February 23, 2005, 01:14:57 pm »
Does the code file already exist?  If so, I don't think the implementation will be changed if the method already exists in the file.
« Reply #4 on: February 23, 2005, 02:32:12 pm »
For an initial generation (it won't be synchronised) you can put the code for a method into EA under the behaviour tab of the operations dialog (initial code in recent builds).
Simon
