Author Topic: Help Needed! Oracle Server Requires Daily Re-boot  (Read 2783 times)
TP
« on: March 08, 2005, 09:26:50 am »
We recently moved our EA Access database to Oracle 9i.  It works fine, except that each morning we have to re-boot the Windows 2000 server to allow connections to the database.  I cannot see any evidence of missing or stopped processes on the Windows server.  Has anyone seen this before?  I really need some help on this one!!  Please send me a message if you have a solution.  Thanks.
Regards
« Last Edit: March 08, 2005, 09:30:07 am by tparker »
Bruno.Cossi
Re: Help Needed! Oracle Server Requires Daily Re-b
« Reply #1 on: March 08, 2005, 09:32:32 am »
what version/release of Oracle do you use exactly? Try the following first, that will help to pinpoint where exactly the problem is:
1. Connect to your database from SQL*Plus on the server
2. Connect to your database from EA installed on the server
3. Connect to your database from SQL*Plus on another machine
Can you tell me what error message do you get? Including the ORA number.
Also, do you use static or dynamic IP address?
Bruno
TP
« Reply #2 on: March 08, 2005, 03:48:36 pm »
Thanks for the reply Bruno.Cossi
The version of Oracle is 9.2.0.1.0
The error message that we receive is as follows:
"ORA 12505 TNS Listener could not resolve SID given in connect descriptor".
The user is also prompted for a password, although it is supplied in the connect string.
Regards
« Last Edit: March 08, 2005, 03:49:33 pm by tparker »
Bruno.Cossi
« Reply #3 on: March 08, 2005, 03:55:15 pm »
As per my e-mail, please have a look at the services on the server and make sure that the listener is running. If not, have a look at the Oracle log, you can send it to me and I will try to track down what is bringing it down.
If the listener is up, make sure that your client machine can connect to the server one.
Bruno
