Author Topic: Object lifetime in sequence diagrams  (Read 3516 times)
warmachine
  • I'm not prejudiced.  I hate everyone equally!
« on: March 08, 2005, 03:41:44 am »
I can't work out how to prevent the deletion of an object after its creator has finished with it and passed it to something else.  Currently, the object appears to be created, has a few properties set, then dies.  This is confusing to read as it's kept by a cache that hangs around for a long time.
Matthew Greet
mikewhit
  • Accessing ....
Re: Object lifetime in sequence diagrams
« Reply #1 on: March 08, 2005, 08:30:46 am »
Surely since all references will be via the cache (otherwise how does it get used), the cache will be involved in the sequence diagram too, holding a reference to the object [Proxy pattern], and so the object will only die when the cache decides it doesn't need it or can't hold it any more.
Or did I misunderstand ?
sargasso
« Reply #2 on: March 08, 2005, 01:56:13 pm »
Object lifetime vs. focus of control????
warmachine
« Reply #3 on: March 09, 2005, 03:32:04 am »
Indeed, that is how it works and the cache is on the diagram with the function to store the object in it.  There is no way to state that a function parameter is stored in object state (not that I want that in a CASE tool).  But the created object still dies.
Matthew Greet
