Author Topic: How to disable Security  (Read 2398 times)
Dan_Lundy
« on: March 09, 2005, 09:36:52 am »
I have security turned on in several models. Now, for the first time, I need to turn it off.
The documentation gives me the impression that if it is enabled then the Project | Security| *Dis*able option should show up. It doesn't.
Suggestions?
DanL
Bruno.Cossi
Re: How to disable Security
« Reply #1 on: March 09, 2005, 10:53:34 am »
Hi Dan,
the menu option is still called "Enable Security", but when the security is enabled, the menu option is checked. To disable the security, you will need the same authorization key you have used when enabling it.
Hope this helps!
Bruno
