Author Topic: Combining / merging actor and object elements  (Read 3140 times)
atw
« on: March 15, 2005, 06:58:21 am »
Hello everyone,
I am creating a business object model (yes, the big one) and a business use-case model.  I am at a stage where I have object elements in the BOM that are equivalent to actor elements in the business use-case model (i.e. a company object in the BOM has an equivalent company actor in the use-case model).
The question that I have is: what are some good ways to merge these two models?
- Should I  merge one of the element into the other (e.g. delete object elements that have equivalent actor elements)?
- Should I keep both elements and indicate in some fashion that they are equivalent?
- Any other methods?
Any suggestion will be appreciated.
Thanks!
Nick
Re: Combining / merging actor and object elements
« Reply #1 on: March 15, 2005, 08:20:45 am »
I would keep both in parallel. When I create a BOM I have a very abstract sight of the system. I put it in a separate package somewhere in the top of the browser. When I later come to the use case view I normally create the actors again. I do not have a reason for that - just my stomach. In the business view I describe the actor in a much more abstract way. Later when it comes to use cases I have this 'duplicate' actor with use case related information which I normally would not like to have in the business view. It's also advisable to stereotype actors in the business view as business actors (as in RUP?).
atw
« Reply #2 on: March 15, 2005, 08:51:46 am »
Thomas,
Thank you for responding to my question so quickly!
Just to clarify, are you using UML actor elements in both the business view and the business use-case view or are you using UML object elements in the business view and UML (business) actor elements in the business use-case view?
Thanks again!
Nick
« Reply #3 on: March 16, 2005, 02:50:07 am »
I do use simple actors. I found my own style which has a bit of Eriksson-Penker and Sparx. Most of the time the icons from the analysis toolbar suffice to show what I need to show. Just to distinguish between the both views I stereotype the actors in the BOM as <<business actor>>.
There are some threads about business object modelling in this forum. Try searching for "penker" as Eriksson is more likely to be written the wrong way  ;)
