Author Topic: Package names  (Read 3804 times)
priyakubher
Package names
« on: March 16, 2005, 01:10:52 pm »
I am trying to move elements from one package to another. But when I do so the use case digrams list the old package name in the diagram. How do I get rid of it? I tried a few options but nothing has worked.
Priya
Bruno.Cossi
Re: Package names
« Reply #1 on: March 16, 2005, 01:51:53 pm »
just to make sure I understand this correctly: you have a Use Case diagram with Use Cases on it, you have the option "Highlight Foreign Objects" switched on, you move the Use Cases to another package, but leave the Use Case diagram in its original location, and even though you have moved the Use Cases, their location as displayed on the Use Case diagram has not changed. Is that correct or did I misunderstand?
Bruno
Re: Package names
« Reply #2 on: March 17, 2005, 03:23:22 am »
AFAIK this issue has been discussed recently. Try closing and reopening the diagramm. I remember this being a refresh issue (should have been fixed meanwhile?).
priyakubher
Re: Package names
« Reply #3 on: March 21, 2005, 10:42:24 am »
Thanks a bunch ,
The refresh trick worked!
Priya
