Author Topic: Reverse engineer "XML Schema to UML Class dia  (Read 4372 times)
dhore
« on: March 21, 2005, 03:55:57 pm »
Through EA we can forward engineer a Class diagram to XML Schema, but I have a requirement to 'reverse' engineer a XMl Schema.....is it possible?...If it is, pls let me know the steps.
- Dipak
Molto Mike
Re: Reverse engineer "XML Schema to UML Class
« Reply #1 on: March 21, 2005, 10:55:21 pm »
it is currently not possible, but there seems to be a possible workaround... See this previous post:
http://www.sparxsystems.com.au/cgi-bin/yabb/YaBB.pl?board=general;action=display;num=1106878388
Mike
englishteeth
« Reply #2 on: March 22, 2005, 12:39:03 am »
I used an eclipse 3 plug-in called hyperModel to read in the schema, from that I was able to do an XMI export which EA accepted without any problem.
Ian
