Author Topic: Page Setup's landscape option disabled  (Read 3942 times)
mylesr
  • Howdy!!
« on: March 19, 2005, 07:13:15 am »
This was working the other day, but now when I go into either File|Page Setup or the properties for a diagram, the landscape option is disabled.  I would like to set the page setup seperately for each diagram as needed.
mylesr
  • Howdy!!
Re: Page Setup's landscape option disabled
« Reply #1 on: March 19, 2005, 07:27:04 am »
I figured out what was going on.  My default printer is attached to a remote machine that wasn't turned on.  Without being able to talk to the printer, it wouldn't let me change the diagram orientation.
Is this dependancy really necessary?
mikewhit
  • Accessing ....
Default printer settings for EA
« Reply #2 on: March 21, 2005, 02:34:41 am »
This reminds me of a gripe I have with Windows printer philosophy.
For applications like EA which produce diagrams, you might wish to have a 'diagram printer' distinct from a 'report printer'.
Windows always assumes your 'default' - which might be different for different apps or even different documents (availability of colour, A3 paper, landscape/portrait, default settings, etc.).
Test cases as produced by EA work best as landscape ...
So it would be a step forward if EA could allow you to customise your 'printing defaults' (and default printers) for particular purposes.
« Reply #3 on: March 22, 2005, 12:57:41 am »
Yes Mike, that would really be an improvement :)
To overcome the "turned off printer" problem: I installed a PDF printer (freeware) and use that as default. So my printer settings are always the same. When the need for direct printing comes I switch to the appropriate printer (and I'm astonished that the layout is completely different then).
