Author Topic: synchronizing existing model with code  (Read 2296 times)
Cryolitte
« on: March 22, 2005, 02:10:52 pm »
Hi all,
I'm doing a fair bit of reverse engineering from code that is constantly evolving. This means that methods, attributes, and classes are added and deleted frequently (to the code, that is).
Under Tools -> Local Options -> Generation -> Attribute/Operation, there are only options to delete methods and attributes not in code (when reverse synch).
So my question is: upon reverse synch, can I have the classes, that are in the model and not in code, deleted?
TIA.
Re: synchronizing existing model with code
« Reply #1 on: March 22, 2005, 03:41:32 pm »
The short answer is no.
The long answer might be something like...
EA only touches the classes that it sees in code when reverse engineering.  I could imagine it seeing that a file doesn't exist, or that the class isn't contained in the file specified.
Then I imagine someone working on a model, doing a reverse engineer and their classes get deleted because they haven't been generated yet.
Having said that, I imagine that it may be possible to write an addin that delete classes in the model not found in code on either of the conditions above.
Simon
