Author Topic: Local path and PHP?  (Read 2454 times)
reddog
Local path and PHP?
« on: March 22, 2005, 06:23:57 am »
Hi all,
How can I add PHP as an option for the loca path type?
Reddog.
Re: Local path and PHP?
« Reply #1 on: March 22, 2005, 03:50:39 pm »
If you create a path in another language and edit the paths.txt file in your EA directory you can create a path for PHP that way.  You still can't edit the path or use the apply and expand buttons in EA though.  But if you do a generate or reverse for PHP with that path it will work.
If you need to use the apply and expand buttons then you will need to temporarily set the language to something else.  Rather than do this for each class manually (which defeats the purpose of the local paths).  The context menu for a package contains the following command. "Code Engineering" | "Reset Options for this Package".  Use this to set the language to something else and back again after using the paths, but don't reset anything else.
I know this isn't nice, but I hope it helps.
Simon
