Author Topic: What is an ERLink?  (Read 4934 times)
JimF
What is an ERLink?
« on: March 30, 2005, 11:53:21 am »
I searched help and the forum but found nothing. :-/
Re: What is an ERLink?
« Reply #1 on: March 30, 2005, 03:11:31 pm »
I believe it's been superceded now, but it used to be the foreign key association between two table elements. Why do you ask? Questions like that make me nervous!  :-/
JimF
« Reply #2 on: March 30, 2005, 03:26:57 pm »
Because I think the arrow at the end of the association I think will confuse my users, for whom an arrow always means "something flows to something". The multiplicity label is there, that's nice, but I wanted to get rid of the arrow, maybe put crow's feet, but at least get rid of the arrow. I changed the connection type to ERLink (I figured ER maybe stood for Entity-Relation) and I didn't get crows' feet but I did get rid of the arrow. Then I decided to check it out, but couldn't find it in the help or even on the forums everywhere. Shouldn't everything be documented somewhere? I have found in my brief experience with EA that there seems to be a lot of little things like this that aren't documented, or at least not well.
Tell you what, though, once I changed the connection types and also got rid of the PK and FK name labels on the connections, leaving just the field= field and multiplicity, I had a pretty nice little set of ERD diagrams. :) And it's easy to copy to Word.
« Reply #3 on: March 30, 2005, 04:44:16 pm »
Hmmm, I was right to be nervous, it probably shouldn't be in that list. :-/
It's a deprecated feature, still there to support legacy models, so it has been removed from the documentation. For new models, associations give you every the ERLink used to.
Two additional choices for you: 1. Tell your users the foreign key "points to" the primary key, hence the arrowhead. 2. Right click the association and set Direction to Unspecified.
Hope this helps
JimF
« Reply #4 on: March 30, 2005, 06:18:03 pm »
OK, guess I'll go with option #2, thanks.
I think EA works real well for me as a ER diagrammer. As for the rest of the UML, I'm reading books but not quite "getting it". I shall keep trying.
