Author Topic: Generate DDL Error - DEFAULT NOT NULL  (Read 4598 times)
Ian_Robinson
« on: March 30, 2005, 08:57:11 am »
Hi ,
Im running  build 750, and my DLL generation now outputs a   "DEFAULT NOT NULL"  - if i have set the column property to NO NULL.
This is not how is used to work, and i cant seem to switch  this off.
E.g.  my table DDL looks like this
CREATE TABLE Manufacturer (
   ManufacturerId VARCHAR(40) DEFAULT  NOT NULL,
   ManufacturerName VARCHAR(50) DEFAULT  NOT NULL,
   ManufacturerCountry VARCHAR(20) DEFAULT ,
   ManufacturersWebsite VARCHAR(255) DEFAULT
Also if i set the comment level to = "None", it still outputs
COMMENT ON TABLE Manufacturer
   IS 'Switch Manaufacturers'
Regards
ololett
Re: Generate DDL Error - DEFAULT NOT NULL
« Reply #1 on: April 01, 2005, 05:26:37 am »
Hi Ian
How could you generate the ddl?. I have the problem that i can't see the 'Generate ddl ...' when i activate the table in the diagram an rightclick on it.
Best regards
Martin
Ian_Robinson
« Reply #2 on: April 01, 2005, 05:41:06 am »
If you create a Analysis Diagram , and drop on a TABLE  you will be able to  right click on the Table object and select DDL Generate.
Bruno.Cossi
« Reply #3 on: April 01, 2005, 08:04:47 am »
it does not have to be an Analysis diagram, in fact I suspect Class diagram would be the most common choice, the option works on any diagram type as far as I know.
Bruno
Bruno.Cossi
« Reply #4 on: April 01, 2005, 08:05:23 am »
Hi Martin,
what edition of EA do you have? The desktop edition does not have support for database engineering. See here: http://www.sparxsystems.com.au/Editions.htm
Hope this helps!
Bruno
Hi Ian
Best regards
Martin
ololett
« Reply #5 on: April 01, 2005, 01:10:22 pm »
Hi Bruno
Many thanks - that's it.
I have a Desktop Edition. According to the table of features http://www.sparxsystems.com.au/Editions.htm the generation of ddl doesn't work.
I suggest that the help file is extended with this remark.
Best regards
Martin
