Author Topic: Generalization Sets  (Read 6799 times)
atw
Generalization Sets
« on: January 17, 2005, 11:14:44 am »
Is there any way to group generalization links into sets similar to how Martin Fowler describes it in his book "UML Distilled"?
I know that EA can attach notes or constraints to generalization links.  However, the notation is different than Fowler's method and I do not see if there is any method to report the different types of generalization links that a class may have.
Thank you,
Re: Generalization Sets
« Reply #1 on: January 19, 2005, 12:38:15 am »
I haven't read Fowler, so I can only guess what you mean by grouping. Could you use a stereotype to represent these groups?
atw
« Reply #2 on: January 19, 2005, 05:56:23 am »
Thank you for responding to my question!
First, a generalization set is a group of generalization-type connectors with a common target superclass.  Typically, the subclasses connected with connectors within a generalization set are mutually exclusive subclasses that have a common classification.
For instance, a superclass "person" can have subclasses: male and female.  A good name for a generalization set for the generalization connectors from these two subclasses would be "sex".  The same superclass "person'" can also have subclasses: doctor, lawyer, accountant, programmer, etc.  A good generalization set name for the generalization connectors for these subclasses would be  "occupation".
To some degree, I can use stereotyped connectors.  However, with a large domain model there will be a lot of different connector stereotypes.  Additionally, the notation would not be as clean as the UML 2 generalization set notation.
sargasso
« Reply #3 on: January 19, 2005, 01:55:24 pm »
Do you have the spec reference for this?
bruce
« Reply #4 on: January 19, 2005, 02:22:03 pm »
UML 2 Superstructure, Section 7.17.3 GeneralizationSet.
We don't have an actual GeneralizationSet element: you would represent one using the tree style connectors and attach a constraint. That may not be enough (specifically the tree style notation doesn't cope when one parent has more than one GeneralizationSet) so we probably need to have a think.
jeshaw2
« Reply #5 on: January 22, 2005, 06:24:24 pm »
Please, Please...think hard.  I use this a lot in data modeling.
Owl Saver
  • Never give up.
« Reply #6 on: March 02, 2005, 05:56:14 pm »
Please take my comments with the proverbial grain of salt. I have been using Object Oriented Modeling since the early 1990's and have found the approach described below to be intuitive but hard to work with.
Specifically, Sex is an attribute of a person, not a sub type. Doctor, Lawyer, etc. are roles. This is best handled by containership.
The bottom line is to model something as it is. For example, I am a person. I happen to be a Spouse, an Employee, a parent, and many other things at points in time. So, I am a type of person but I inhabit these roles over time.
In my experience, this creates much more resilient systems.
atw
« Reply #7 on: March 03, 2005, 01:30:26 pm »
Thank you for your input!  I actually created my models to follow the methodology as you described.  In the case with person class, I modeled person, relationship, and role.
« Reply #8 on: April 01, 2005, 05:52:38 pm »
>hard to work with.
I've been an Object Modeler since 1978, and a Data Modeler
since the mid 80's.  Yes, you can be both without suffering
bipolar disease! :-)
>containership.
The attribute is contained, but as a consequence of having the
attribute value (male/female] the resulting subclass has
different attributes and operations.  This is exactly what the
UML2 Generalization Sets and Powertypes is trying to model (and
it's a great step forward).  In the Data Modeling domain, we're
quite used to these concepts and it was disheartening to see UML
1 didn't support this.  Now UML 2 DOES!
You are quite right, these latter concepts are roles and should
be modeled as such.  In particular, since many of these roles
are dynamic, using static inheritance would be problematic.
This is undoubtedly true...  A correct conceptual model
literally "designs out" whole classes of problems that many
systems suffer from.
