Author Topic: Oracle ODBC Driver's Required for Reverse Engineer  (Read 6534 times)
bjw122
« on: August 01, 2007, 07:26:23 am »
If I want to use the reverse engineering feature against an Oracle 10gR2 database are the Oracle ODBC drivers a required installation?
I'm using EA Corporate Edition.
In the EA Help, under "Setting Up a Database Repository", "Setting Up an ODBC Driver" sub-section it states that:
"Setting up an ODBC driver is only necessary for MySQL, PostgreSQL and Adaptive Server Anywhere. The other supported databases connect using OLE DB, so this stage can be skipped."
However, I'm not setting up a database repository, I'm trying to use the reverse engineering feature.
Thanks.
hd
Re: Oracle ODBC Driver's Required for Reverse Engi
« Reply #1 on: August 01, 2007, 01:03:20 pm »
Database reverse engineering is through ODBC, and yes, you need Oracle's ODBC driver.
bjw122
« Reply #2 on: August 02, 2007, 02:26:07 am »
Got it, thanks.
