Author Topic: duplicate code from forward engineering  (Read 2466 times)
Cryolitte
« on: April 05, 2005, 11:14:11 pm »
Hi all,
I've reverse engineered from some C# code that we have into an EA model through MDG plugin for VS.Net. After a little bit of test modifications to the model, I then forward engineered it to synchronize with the code.
The Merge option only seemed to pick up new entities, not changes within an entity, so I tried using the option Generate Code (forward engineer).
BUT... Why do I get duplicates of everything? Every method, inner structures...etc. are duplicated within the .cs file every time I run Generate Code (forward engineer)?
TIA
Cryolitte
Re: duplicate code from forward engineering
« Reply #1 on: April 06, 2005, 03:22:28 am »
Hmmm... Let me correct myself. After some testing with dummy VS.Net projects, it seems the problem is with C# struct.
For example...
class MyClass{
 public struct MyStruct{
   public string attr1;
   public string attr2;
after forward engineering, the original code would be turned into...
class MyClass{
 }//end MyStruct
I don't understand why there is a duplicate. Could this be something wrong with the code generation templates?
« Reply #2 on: April 06, 2005, 11:29:13 pm »
It's not a problem with the code templates and is a bit different from what you said.
Currently inner classes aren't being recognised for synchronisation.
This should be fixed for build 751.
Simon
