Author Topic: split projects in more then one *.EAP-file  (Read 5659 times)
Whisky
« on: April 06, 2005, 05:17:06 am »
Is it possible to split big projects in more then one *.EAP files? For example, i have one Component-diagramm and each component points to here own *.EAP file.
Thanks Lutz
Re: split projects in more then one *.EAP-file
« Reply #1 on: April 07, 2005, 01:02:18 am »
Splitting into multiple .EAP is possible in theory. You have to control packages via XMI ex-/import. But the better way is surely to migrate to a SQL server. EA supports MS SQL, Oracle, mySql and others.
Whisky
« Reply #2 on: April 07, 2005, 03:00:05 am »
Thanks! I will try it.
Regards Lutz
Bruno.Cossi
« Reply #3 on: April 07, 2005, 08:26:16 am »
Hi Thomas,
how does migrating to a SQL server help with splitting the model into multiple ones?
Bruno
« Reply #4 on: April 07, 2005, 09:10:19 am »
 It was not my intention to help splitting but circumvent the cause for splitting. I should have asked why Whisky wants to split project. I simply assumed it was for performance reasons.  :-[
Whisky
« Reply #5 on: April 08, 2005, 01:16:31 am »
I have a lot reasons for split:
- more then one developer at different places (online and some times offline)
- we have to use a source safe tool
- a very large project
- not all of diagramms are for publishing  ;D
The solution with Visual Source safe is working fine, but we have to use Clear Case (Rational).
Anybody try it?
Thanks for help
Lutz
« Reply #6 on: April 08, 2005, 01:24:27 am »
Not me, but I remember it has been discussed in the forum (try a search for clear case). I also remeber that it worked...
Regarding your first question I was not too far away :) Most of your concerns could be solved using a SQL server and EA's security mechanism (you need a corporate license).
« Last Edit: April 08, 2005, 01:28:00 am by thomaskilian »
Whisky
« Reply #7 on: April 08, 2005, 05:43:43 am »
Thanks! It's working in ClearCase. Some little problems, but i'm hopefully to resolve it   ;D
@Thomas:  ...you need a corporate license... this is a problem too, we use only professional version  :-[
have a nice weekend
« Reply #8 on: April 08, 2005, 06:01:25 am »
I don't have exact numbers but the upgrade price is quite moderate. You could start testing with 2 upgraded licenses and then decide.
Have a nice weekend too  :)
