Author Topic: Bug with Delphi code  (Read 5296 times)
Jeanluc
« on: April 06, 2005, 12:37:45 am »
I'll try to explain the problem.
1) Create a class without elements (attributes, operations, etc.)
2) Generate delphi code. In .pas file, you get:
   constructor Create; overload;
   destructor Destroy; override;
3) Return to EA, do a reverse engineering to recreate class in EA diagram. The reverse is ok in diagram.
4) Now, regenerate code and go to Delphi to see generated delphi code. You see:
   procedure Destroy; override;
Destroy is totally false ... It's a destructor, not a procedure ...
A good idea to correct this in future version ?
Jean-Luc !
Re: Bug with Delphi code
« Reply #1 on: April 06, 2005, 11:00:45 pm »
Yes, I'd say it would be a good idea to fix it.   ;)
Until it is the fixed templates should look like this.
Edit: I forgot to mention that I will be fixing it.  It should be fixed for build 751, but if not then it will be in the following build.
Operation Declaration
%PI=" "%
%if opName == "Create"%
$op_type = "constructor"
%elseIf opName == "Destroy"%
$op_type = "destructor"
%elseIf opReturnType == "" or opReturnType == "void"%
$op_type = "procedure"
%else%
$op_type = "function"
%endIf%
%PI=""%
$params = %list="Parameter" @separator="; "%
%if $params != ""%
$params = "(" + $params + ")"
%endIf%
%PI=" "%
%opStatic == "T" ? "class" : ""%
$op_type
%PI=""%
%opName%$params
%if $op_type == "function"%
: %opReturnType%
%endIf%
%if opPure == "T" or opAbstract == "T"%
; virtual
%endIf%
%opAbstract == "T" ? "; abstract" : ""%
%if opTag:"overload" != "" or $op_type == "constructor"%
; overload
%endIf%
%opTag:"reintroduce" ? "; reintroduce" : ""%
%opTag:"override" == "true" ? "; override" : ""%
Operation Declaration Impl
%PI=" "%
%else%
%endIf%
%PI=""%
%if $params != ""%
%endIf%
$op_prefix = $op_type + " " + %className% + "."
%opStatic == "T" ? "class " : ""%
$op_prefix%opName%$params
: %opReturnType%
%endIf%
;\n
« Last Edit: April 06, 2005, 11:31:46 pm by simonm »
Jeanluc
« Reply #2 on: April 07, 2005, 02:12:41 am »
Thanks ! The last generated code is correct but format is bad.
type
 Test = class
 public
                  constructor     Create       ; overload    ;
                  destructor     Destroy        ; override ;
 end;
implementation
{implementation of Test}
           constructor Test.Create   ;
 begin
end;
           destructor Test.Destroy   ;
 begin
end;
end.
But it's better than old ..  :D
Jean-Luc
« Last Edit: April 07, 2005, 02:18:17 am by Jeanluc »
« Reply #3 on: April 07, 2005, 03:12:51 pm »
The problem with the formatting is that when copying the template from here it added an extra space to every line.  Each one was then generated, exactly as it should.
sargasso
« Reply #4 on: April 07, 2005, 04:29:45 pm »
(Sorry Simon - I just want to make this a bit clearer).
When copying code (or any text) from yabb forums, because of the html used you will get an extra blank line between each line.  So you need to go through a clean up step using a text editor (or even word if you want) to remove the extra lines before pasting it into your destination.
bruce
« Reply #5 on: April 07, 2005, 06:14:44 pm »
That's fine Bruce.
That's interesting though, I only get an extra space at the end of every line.  (And that's what it looks like Jen-Luc got)
I wonder, is it a browser thing as well?
Simon
Jeanluc
« Reply #6 on: April 10, 2005, 11:35:45 pm »
Thanks a lot !  :) I'll clean it !
