Author Topic: Reverse Engineering and associated Templates  (Read 2616 times)
sbarkeruk
« on: April 08, 2005, 01:27:35 am »
I am trying to understand how the reverse engineering process works with EA. Are templates always used or is a lot of work done in the underlying code instead?
In other words, can I change most of the functionality for importing projects or not (as I can with Code Generation)? If so, which is the main Template(s) that is used?
Do you have a flow chart (or UML diagram) that would show the import process and how the Templates work  with this?
The reason I ask is that I would like to try out a number of things, the main one being to see if I can get EA to look for *.vbp (VB6 project) files and add these as a component (with stereotype StandardExe, ActiveX Exe, ActiveX DLL, etc) in a the component view (so that I can match the functionality to that of your competitors). This would be most useful to me, and I'm sure many other developers too.
Simon
Re: Reverse Engineering and associated Templates
« Reply #1 on: April 11, 2005, 03:31:27 pm »
There aren't currently any 'import templates', we are working on a grammar based solution, but haven't released it yet.
Simon
