Author Topic: Data Model: Oracle RAW (size)  (Read 3106 times)
mariec
« on: April 12, 2005, 08:27:16 am »
Is there a way to set the size of a RAW type field in a data model diagram?
The generated DDL never includes this type of information and Oracle requires a size for a RAW field.
Bruno.Cossi
Re: Data Model: Oracle RAW (size)
« Reply #1 on: April 12, 2005, 08:54:29 am »
try going to the menu Configuration > Database datatypes and modify the RAW definiton there (actually, you may have to delete it and create a new one).
Hope this helps!
Bruno
mariec
« Reply #2 on: April 12, 2005, 11:36:19 pm »
Thanks for the tip! I had to play around, the pre-defined datatypes can't be deleted so there are two options:
- play around with the "ddl_datatypes.xml" before you create your project
- create a new RAW datatype, delete it. This deletes both RAW types. Then recreate it again
I had to do with second option since my project was too advanced to start all over.
Thanks again
Bruno.Cossi
« Reply #3 on: April 13, 2005, 06:00:55 am »
You're welcome! It might be worth reporting it to Sparx as a bug, too.
Bruno
Thanks again
