Author Topic: Select 2 links name! Is it a bug ?  (Read 2521 times)
Jeanluc
« on: April 14, 2005, 01:23:38 am »
I select a controlflow name on diagram, I keep Ctrl key pressed and I select another controlflow name. Then EA create a new activity symbol on diagram.
Is it normal or is it a bug ?
Jean-Luc
Re: Select 2 links name! Is it a bug ?
« Reply #1 on: April 14, 2005, 02:26:38 am »
Each time you Ctrl-click on the diagram, EA repeats the creation of the last selected element. In that way you can plaster diagrams with many elements in short time. Similarly you can use F3 to repeat the last relation.
Edit: to answer you question  ;) You can not select multiple flow names. So EA assumes (obviously) that you ctrl-click to create a new element.
« Last Edit: April 14, 2005, 02:37:24 am by thomaskilian »
Jeanluc
« Reply #2 on: April 14, 2005, 02:51:49 am »
Thanks a lot !
