Author Topic: Multiple applied note appearence  (Read 2850 times)
« on: April 14, 2005, 11:22:42 pm »
When you apply a note to more then one line, the note connectore seems to be part of the note.  When you attach a single note, it isn't.   ???
When I adjusted the appearance of the note, I expect ONLY the note to change - not the connector as well! ::)
Please fix.
A third example in as many elapsed hours of the line-shape dichotomy!
« Last Edit: April 14, 2005, 11:23:50 pm by PaoloFCantoni »
Re: Multiple applied note appearence
« Reply #1 on: April 15, 2005, 12:48:57 am »
I can't really figure out what the point is. I do not see any different behaviour if one or two connectors are attached.
« Reply #2 on: April 15, 2005, 12:53:23 am »
That may possibly be because in EA you may not be able consistently apply notes to more than one object.
What I'm doing is attaching a note to a line and then checking some additional boxes.  The appearance behaviour in this case is different than if I attach a note to a shape - where that dioalog doesn't come up - the sujectof another post... :-[
How are you attaching to more than one object?
« Reply #3 on: April 15, 2005, 05:10:42 am »
I guess you mean the ability to connect the note contents to an element feature. Yes - you only can attach one at a time. If you want a simple note you have to do it the following way: right click the relation and attach a note (to this and other relations on the diagram). Then draw link lines (icon in the top area) between the note and any object.
