Author Topic: Import EA generated XMI (1.0/1.2) files  (Read 3988 times)
nicholas_yue
« on: April 14, 2005, 04:56:43 pm »
 I could not find any SVG export in EA so I am exporting it to Gentleware Poseidon to generate the SVG diagram.
 When I tried to import the XMI file, Poseidon claims that the EA generated file is not MDR compliant.
 Anyone know the trick to transfer XMI from EA to Poseidon?
 I thought the whole idea of XMI is to ease model interchange.
Cheers
Re: Import EA generated XMI (1.0/1.2) files
« Reply #1 on: April 15, 2005, 12:20:12 am »
You could try Rose XMI. Tools/Options/XMI Specifications
nicholas_yue
« Reply #2 on: April 15, 2005, 04:19:33 am »
Tried that, still not importing properly.
I read the documentation in EA about limitation in XMI, maybe it's just my luck.
Cheers
VK
« Reply #3 on: April 17, 2005, 05:48:01 pm »
Hi nicholas_yue,
EA doesn't have the option to write out the diagrams in SVG format.
As a workaround for generating SVG diagrams, export to Unisys/Rose Format XMI1.0 in EA by :
* CTRL + ALT + E
* Check both Unisys/Rose Format and XMI 1.0 options
Import the file in 'MagicDraw UML' and then save the graphics as SVG file  :)
Cheers
