Author Topic: I can't create Virtual Document object  (Read 3397 times)
vitmatejka
« on: April 18, 2005, 02:14:45 am »
Does anybody know why I can't select stereotype "Model Document" in the class properties dialog? "Model Document" isn't in the list.
I'm using EA corporate edition, 4.51.
Thank's in advance!
Vit Matejka
Bruno.Cossi
Re: I can't create Virtual Document object
« Reply #1 on: April 18, 2005, 05:47:50 am »
do you mean that it doesn't appear in the list? Go to menu Configuration > UML > Stereotypes and simply add it to the list. You can also just type it into the class' stereotype field, even though it may not be in the list.
Hope this helps!
Bruno
Thank's in advance!
Vit Matejka
« Reply #2 on: April 18, 2005, 06:16:40 am »
Be sure to put the blank inbetween!
vitmatejka
« Reply #3 on: April 18, 2005, 06:57:35 am »
Thank you o lot, it works.
One more question:
I have a document object with Requirements package and Use case model package.
I would like to generate documentation with all reqirements and all (and better with selected diagrams) use case diagrams with all details of their objects.
Is it possibe? How?
I recieve only documentation of my document object and no details about embedded packages.
Can I generate doc for one element in HTML?
Thank's
Vit Matejka
« Reply #4 on: April 18, 2005, 12:49:38 pm »
Carefully check the options page for the RTF generation. Several options are for turning on/off details.
