Author Topic: Copying Class Diagrams into Word  (Read 3014 times)
tbrierly
« on: April 19, 2005, 02:48:21 pm »
I'm copying class diagrams into a Word document, and finding that when I paste it it appears with the letters "cd" within a diagonal line in the upper left hand corner.  I have tried everything I can think of to remove this.  I definitely do not want it appearing in my Word document.  Does anyone have any suggestions on how to get rid of the "cd" and the line?  So far the only thing that works is to paste into a new image in PaintShop Pro manually remove the letters and line, and then paste that into Word.  This is time-consuming and isn't going to work since I have dozens of class diagrams I need to cut and paste into Word.
Thank you!
Bruno.Cossi
Re: Copying Class Diagrams into Word
« Reply #1 on: April 19, 2005, 03:53:28 pm »
go to menu Tools > Options, section Diagram. Make sure the checkbox Diagram Frames > On Clipboard Images is unchecked.
Hope this helps!
Bruno
Thank you!
tbrierly
« Reply #2 on: April 20, 2005, 11:41:09 am »
That worked, thank you!  I knew there had to be an answer somewhere...
« Reply #3 on: April 20, 2005, 12:57:35 pm »
Indeed many times ;D
