Author Topic: Controlled Package bug?  (Read 3318 times)
Justin Halls
« on: April 22, 2005, 03:44:26 am »
When I control a package and save this, I get an "Error writing XML file" (using the default XML settings). Is this a known issue and are there any workaround? The destination file&folder are writeable.
Version control is not used (SCC nor CVS).
EA version is 4.51.751 on NT.
Re: Controlled Package bug?
« Reply #1 on: April 22, 2005, 03:55:02 am »
Does this happen for any package/repository or just single ones? (I don't have an idea, just trying to find more details.)
Justin Halls
« Reply #2 on: April 22, 2005, 03:56:44 am »
Happens for all controlled packages....
« Reply #3 on: April 22, 2005, 05:53:19 am »
I found the following in the board:
http://www.sparxsystems.com.au/cgi-bin/yabb/YaBB.pl?board=general;action=display;num=1087566977;start=0#0 looks alike :-/
http://www.sparxsystems.com.au/cgi-bin/yabb/YaBB.pl?board=Latest;action=display;num=1107906615;start=0#0 reports an error correction regarding your problem. If you are pre 747 try to upgrade. If not you should submit a bug report
Justin Halls
« Reply #4 on: April 22, 2005, 07:30:36 am »
yes, its the same problem. I have build 751. Interesting note: it does not happen all the time on all the packages on all the computers.
« Reply #5 on: April 25, 2005, 01:59:46 am »
If you are able to reproduce it, send a bug report to Sparx.
