Author Topic: Artifacts inside Nodes  (Read 3343 times)
Bill Egge
« on: April 25, 2005, 05:59:58 am »
Is it possible to have an artifact contained by a node?  I have only found a way to place the artifact on the diagram and connect it to the node with a <<deploy>> association.  But I have not found a way to insert the artifact "inside" the node.
« Last Edit: April 25, 2005, 06:00:26 am by begge »
alexander
Re: Artifacts inside Nodes
« Reply #1 on: April 25, 2005, 07:19:19 am »
Nodes can be composite artifacts, meaning you can use then as a package or diagram (inserting elements inside)
You can drag and drop any artifact into the node in the project browser but i would also recommend keeping the relationship so you can use the matrix to 'see' the relationship.
Hope it helps...
« Reply #2 on: April 25, 2005, 07:33:55 am »
 :) Funny that I was asking a quite related question just a few minutes ago: http://www.sparxsystems.com.au/cgi-bin/yabb/YaBB.pl?board=UMLPRO;action=display;num=1114428854
