Author Topic: [BUG] xmi export has a bug  (Read 7102 times)
HarryMuc
« on: April 25, 2005, 02:28:00 am »
hey y'all!
I think I just found a (small but - for me - annoying) bug. I use EA to design a model and export it to XMI which I further process with another tool. In my model, I have tagged values attached to a package. This reference isn't exported correctly.
The package has the xmi.id "EAPK_..." while the tagged value references the id "EAID_..." so the tool can't associate the tagged value with the package b/c the ID is wrong.
Maybe you can fix this in the next version. Currently, I edit the xmi file manually before further processing it by replacing the xmi.idref by "EAPK_...".
If it's important: I use 4.50.744 and export the XMI file in Unisys/Rose Format.
-- Harry
HarryMuc
Re: [BUG] xmi export has a bug
« Reply #2 on: April 25, 2005, 04:05:59 am »
I read through the changelog and didn't find anything relevant?! However, I just downloaded the latest version and it still references "EAID_..."
<Foundation.Core.ModelElement xmi.idref="EAID_6D0BD6D6_B039_4af0_955D_D1C0309BE918"/>
<Model_Management.Package xmi.id="EAPK_6D0BD6D6_B039_4af0_955D_D1C0309BE918">
« Reply #3 on: April 25, 2005, 04:36:30 am »
It was just because the change log told something about XMI and tags and the build was younger than yours. But since your problem still exists - no idea :-/
VK
« Reply #4 on: April 25, 2005, 07:23:16 pm »
Hi HarryMuc,
I could not reproduce your problem.
When I exported the package to Unisys/Rose Format XMI 1.0, and imported them in Poseidon and MagicDraw UML (I am not sure what tool you are using), I could get the tagged value of the package correctly. Also, when I checked the XMI file, the tagged values for the package are being referenced as 'EAPK_' and not 'EAID_'.
So, if you could send in a sample model which reproduces your issue, it would help me in correcting the bug.
You can send the model to : [email protected]
Cheers
