Author Topic: HowTo: Set Many Properties at Once?  (Read 2858 times)
DevilDog74
« on: April 28, 2005, 10:27:47 am »
I need to be able to change the stereotype, and status of many objects / elements at once.
For example, after reverse engineering many BusinessObjects from a VS.NET Project I need to be able to set their status to "implemented", and set their stereotype to "entity", "control", or something else.
Is there a quick way to do this?
Re: HowTo: Set Many Properties at Once?
« Reply #1 on: April 28, 2005, 11:48:03 am »
Some tasks can be done via context menu of packages: Package Control / Update Package Status. The rest needs programming via the automation interface.
« Reply #2 on: April 28, 2005, 08:40:47 pm »
Setting many properties at once is a very useful function.  Some products do this very well.
The "pattern" for this is pretty simple.  If the Sparxians need a hand, they just need to ask the forum... :D
You should submit a bug report.
JimF
« Reply #3 on: May 02, 2005, 08:58:57 am »
I need some help with this too. If I reverse engineer a database with a lot of tables, it's a problem because the link between each one has five labels, and I always want to turn some of them off. Right now I am selecting each association and then "Set Visibility | Set Label Visibility". I don't seem to be able to select multiple associations or somehow set a global property for the diagram. This is costing me quite a lot of time on a large database. :-[
[Correction - 6 labels]
« Last Edit: May 02, 2005, 09:00:00 am by JimF »
