Author Topic: Stereotype management dialog needs extensive rewor  (Read 3056 times)
« on: May 05, 2005, 02:26:01 am »
Copy of a bug report I submitted a few minutes ago...
The stereotype management dialog (Configuration|UML|Stereotypes) needs extensive rework.
  • The stereotype list at the bottom doesn't seem to be sorted in a consistent manner (especially after changes)
  • Since it's a listing of stereotypes, then the stereotype column should be left most.
  • You should be able to filter the list by base class
  • "Applies to" and "Base Class" should have the same name (one or the other or a third, but the same!)
  • When you "Save" a stereotype, the saved values should remain visible, and the save button disabled
  • A copy button would be nice, that would blank out the name, but leave the rest as is.
That's probably enough to be getting on with...
alexander
Re: Stereotype management dialog needs extensive r
« Reply #1 on: May 05, 2005, 05:56:32 am »
I agree, specially with the sorting part, i still can't figure out the logic behind it...
