Author Topic: Import DDL schema from Access DB problem  (Read 4861 times)
ug
« on: May 14, 2005, 04:05:04 am »
I tried to import Database Schema from ODBC. Now I use Access 2000/2002 format. But when I try to import the schema I get error message :
"Unrecognized database format .... "
Where is the point - does it mean that I am doing something wrong OR EA is not able to read this  MS Access format ?
When I use MS Access version 97 it works OK but I can hardly believe that EA is not able to read newer formats of Access DB...
Does anybody know where is the problem?
Thanks a lot for you advice ...
Re: Import DDL schema from Access DB problem
« Reply #1 on: May 14, 2005, 10:26:22 am »
There's a check box on the options page for using JET4 drivers  - try that.  You need JET4 to access MS Access 2000.
