Author Topic: linked requirements in the new rtf generator  (Read 2215 times)
mjtapp
« on: May 20, 2005, 09:53:56 pm »
I've been investigating using the new RTF generation functionality and it mostly seems to work as I expect except for one bit.
EA lets you create link requirements to elements in your model (such as use cases) thru realisation links and, in the old document generator you can choose to show these under the relevant element (e.g. use case).
However, unless I'm missing something there doesn't seem to be a way of doing this in the new generator. I had initially thought that selecting 'Requirement' under 'Element' would cause this to happen, but this doesn't seem to work. Has anyone figured out a way of doing this? Or is it a bug/missing feature?
