Author Topic: What happened to the diagrams?  (Read 3629 times)
kgish
« on: May 22, 2005, 04:38:33 am »
If I generate an RTF-document, I can see the diagrams plainly. However, when I send them as attachments to the boss, he only sees placeheolders (and grumbles a bit).
What setting do I need to change this?
Also, if I indert links within my RTF-documents, do I have to also send the linked documents along with the attachement or is there an easier way to always have the linked contents actually part of the original document.
Thanks alot in advance.
TrtnJohn
Re: What happened to the diagrams?
« Reply #1 on: May 23, 2005, 11:39:01 am »
Quick, before you get fired, check the Embed Diagrams in Document check box located in the lower right side of the generate RTF document dialog!
kgish
« Reply #2 on: May 23, 2005, 11:53:54 am »
Well, I own version 5 and first have to click the [Switch generator...]-button to get to the right dialog: Rich Text Format Report.
But are any changes I make here also reflected in new-style RTF document generator?
Actually I am a little confused about the relationship between the new and old-style template interfaces. Are they independant of each other or are they related (overlap) in some way?
