Author Topic: Local Path & XMI  (Read 2055 times)
davisford
Local Path & XMI
« on: May 24, 2005, 01:51:02 pm »
Hi, I cannot seem to get the local path feature working in EA 5.0 (build 764).  I have a feeling I must be doing something wrong.  Here are the steps I am doing:
Create package Blah in the Project Browser.  Right-Click Package Blah -> Package Control -> Configure...
Control Package [tick]
Version Control: (None)
XMI Filename: Blah.xml
UML/XMI Type: Enterprise Architect XMI/UML 1.3
Log Import/Export [tick]
<click OK>
Configuration -> Local Paths -> <click New>
Path: C:\TEMP\XMI\
Type: XMI
<Click Save>
Select the local path I just created and <click Apply Path>
Dialog box says:
"This will convert existing XMI controlled package pathsXMI to the new relative path.  Do you wish to proceed?"
<click Yes>
Dialog box says:
"Process complete! 0 records affected"
So it appears that this did nothing?
If I go back and right-click Package Blah and choose Package Control -> Configure...
I set XMI Filename to: %XMI%\Blah.xml
<click Ok>
Then I right-click Package Blah and choose Package Control -> Save Package to file
I get an error dialog that says:
"Error writing XML file"
<click Ok>
"Error writing XML Log file"
<click Ok>
How can I make this work?  What exactly am I doing incorrectly?
Thanks in advance!
