Author Topic: Where is the eatest.eap file?  (Read 3975 times)
kgish
« on: May 27, 2005, 01:58:10 am »
I want to have a look at the VB sample project, but it requires a file called eatest.eap somewhere.
Where can I find this file?
TomO
  • EA - Bridging the gap between Business and IT
    • Sparx Systems
Re: Where is the eatest.eap file?
« Reply #1 on: May 29, 2005, 06:30:03 pm »
Hello Kgish,
What is the name of the example file for VB you are using? I don’t believe there should be any dependencies on any EAP file at all.
If you are referring to the AutIntDll example, then the EATEST in that refers to an item of type EA.Test.
What error message are you getting? and when does the error show up? Compile? Runtime?
« Last Edit: May 29, 2005, 06:45:05 pm by TomO »
kgish
« Reply #2 on: May 30, 2005, 10:20:13 am »
I am just using the default VB_Sample.vbp project fine for Visual Basic.
When I fire up the application, it asks for a file called eatest.eap but now I know that any valid file can be used.
