Author Topic: database engineering  (Read 2090 times)
stefanon
« on: June 05, 2005, 11:51:14 pm »
just tested the evaluation version of EA and had the following problems while engineering databases:
import of MySql via ODBC:
- If an index contains more than one field, a own index for each field will be created (works if you import from an MS-Access-database).
export from EA via Generate-Package-DDL (SQL-script):
- if an index contains more than one field, all index-fields will be exported but without an index name => thereby the index will have the name of the first field (works if you import from an MS-Access-database).
Is there a solution for this problems?
many thanks and best regards
Dietmar
