Author Topic: Your use case step labeling approach?  (Read 5320 times)
Pascal
« on: June 08, 2005, 12:32:56 am »
I'd like to label the steps in my use cases' basic path, so that I can refer them from the alternate scenario's. I was wondering what you guys find the best labeling scheme.
Numerous people seem to use the sequential numbering scheme with increments of 1:
 1. Actor does A
 2. System replies B
 3. Actor does C
 4. ...
Inserting a step in this scenario leads to a renumbering nightmare, especially when you have quite a few alternate scenario's. A solution would be not to number sequentially, but arbitrary (only when needed for referral from the alternate scenario):
 - Actor does A
 1. System replies B
 2. Actor does C
Inserting a step between 1 and 2 then yields:
 - Actor does A
 1. System replies B
 3. System asks D
 2. Actor does C
Conceptually I think this is the best, but I think that users have a hard time understanding the logic behind this. Other options are using logical step names instead of numbers. I think that this clouds up the scenario description too much. Last but not least seems to me the old "Basic programming language" approach: number sequentially with increments of 10:
 10. Actor does A
 20. System replies B
 30. Actor does C
 40. ...
This leaves room for 9 inserts between all initial steps, e.g.:
 10. Actor does A
 25. System asks D
 30. Actor does C
 40. ...
Anyone care to share his use case step labeling approach?
Pascal.
Kevin Brennan
Re: Your use case step labeling approach?
« Reply #1 on: June 10, 2005, 01:31:19 pm »
Any approach other than the first strikes me as likely to confuse non-technical users quite badly. I'd suggest that you consider instead Bittner's approach, where you give a name in brackets to the extension point where an alternate scenario can occur:
 1. Actor does A
 2. System replies B
 {Extnesion Point}
 3. Actor does C
 4. ...
If at {Extension Point} Actor does X, then System replies E}.
Sr. Consultant at blue sands Inc. and Vice President, Body of Knowledge at the IIBA. All opinions are my own.
