Author Topic: Dynamic attribute links  (Read 2057 times)
msher
« on: June 24, 2005, 10:02:29 am »
I am looking for a way to provide a documented link between two attributes (in the same or different class).
Currently I am using tagged values for that.
This approach breaks as soon as the referenced attribute or class are moved or renamed.
Is there a way to avoid that?
Ideally I'd look for a predefined tag type, which would provide for a type dropdown list followed by attribute/method dropdown list to produce the tag value. This value would then mutate as the referenced class/attribute are moved/renamed.
I'd be happy to use some other methods (not tagged values) if such are available.
