Author Topic: Keyboard shortcuts to context menu items  (Read 4457 times)
Dani
« on: June 30, 2005, 12:55:47 am »
Is the above possible ?
I have a bunch of connectors in a sequence diagram the source element of which needs to change. Presently I have to individually select each one of them, right click, go connection detail, and then set source and target.
It'd be nice if I could assign a keyboard shortcut to this function. It would also be nice if I could multiple select all the connectors I need to apply the operation to and do it in one go. As far as I can see that's not possible either.
Any suggestions ?
Re: Keyboard shortcuts to context menu items
« Reply #1 on: June 30, 2005, 03:56:08 am »
Shortcuts: Try Tools/Customize/Keyboard
Multiple selection: Still not possible (is EA developed OO?)
Dani
« Reply #2 on: June 30, 2005, 03:59:56 am »
Thomas,
Re customize/keyboard, I tried that before posting, but as far as I can see there's no way to access an option that's only present in a context menu.
« Reply #3 on: June 30, 2005, 04:13:29 am »
Maybe it's possible by writing an add-in. Haven't tried that so far, so actually it's onyl a guess :-/
AshK
« Reply #4 on: June 30, 2005, 04:53:23 pm »
In Ea 767 you can change the source/target of a connector by:
-hold shift, then left click the end that is to be moved
-select the new source/target element
Ash
Dani
« Reply #5 on: July 01, 2005, 01:33:15 am »
Ash,
Thanks a lot. That's an awful lot better than doing it through the context menu.
