Author Topic: Showing Constraints  (Read 4529 times)
Bill Egge
Showing Constraints
« on: July 04, 2005, 02:52:31 pm »
I added a constraint to an attribute of a class, how do I display this constraint in the diagram?
btw - I double clicked the diagram and turned on every attribute that started with "Show" and I also Right clicked the class and turned on everything in the feature visibility dialog.  Still, no constraints are showing.
Re: Showing Constraints
« Reply #1 on: July 04, 2005, 03:12:39 pm »
Constraints on attributes (and operations) can't currently be displayed on the diagram.
baxenath@pxc
« Reply #2 on: January 09, 2019, 02:47:53 am »
Is EA 14 or another version able to show constraints of attributes?
« Reply #3 on: January 09, 2019, 05:03:08 am »
No
Takeshi K
    • Sparx Systems Japan
« Reply #4 on: January 09, 2019, 05:40:46 pm »
Hi all,
The following steps might be workaround:
1. add a Tagged Value which name is 'xUML' to the attribute
(i.e. open the Tagged Value window, then select the attribute and then add a new Tagged Value 'xUML')
2. set its value to what you want to display in the diagram (e.g. "{SomeCostraint}")
t-kouno
