Author Topic: Operation extended properties  (Read 4706 times)
bsimon
« on: September 11, 2007, 06:03:07 pm »
Hello over there,
How can I access an operation's "extended properties" ( Database operation properties dialog fields ) through automation ?
Hope somebody can help me with this,
Re: Operation extended properties
« Reply #1 on: September 12, 2007, 01:51:10 am »
AFAIK you cannot. There is a way to tweak these via the UI, but the extended properties themselves remain documented as read-only.
Although the documentation is being updated, the read-only status for properties appears to remain the case for the API.
You could always open a second channel directly to your model via OLEDB (or whatever) and insert or manipulate records in the t_objectproperties. Be very careful doing this, back up your model, and remember you are on your own if you go this way.
Perhaps you'd like to submit a feature request regarding making properties writable. Please search my recent posts for a best practice we (the user community here on the forum) are using for making such requests while keeping the rest of the community in the loop.
HTH, David
PS: If you are just trying to create stored procedures via automation, you're in luck. EA still supports the 'old' style of stored procedure container. In this case you use a stereotyped class, entering each stored procedure as an operation. Parameters and return type are entered as appropriate. This seems to work well with automation, although I sometimes find the presentation to be a bit constraining. But I guess that's why the new style was adopted - however, the choice of a read-only property for the code was a surprising blunder.
bsimon
« Reply #2 on: September 15, 2007, 05:44:14 am »
Thank you for your reply.
I think I didn´t explain myself well.  What i need is to read the extended properties of an operation such as unique and clustered index properties, cascade delete and cascade update foreign key properties.
I´ve explored all of the "Method" attributes but none seems to provide the information I need.
Thanks again,
« Reply #3 on: September 16, 2007, 08:41:45 am »
I'm sure I knew the answer to this once...
Take a look at tagged values. Perhaps that's where they store the stuff.
I'll try to remember. Meanwhile perhaps someone knows where this stuff is.
