Author Topic: Suppress display of concurrent substates  (Read 3197 times)
jjweis
« on: July 12, 2005, 04:45:51 am »
Hello.
I have a state-machine (lets say on diagram A) with a submachine in it. The sub-machine contains entry- and exit-points.
Then I go to the diagram (diagram B) of the sub-machine. There I put the symbol of the submachine on it and make the entry and exit points visible. I define concurrent sub-states on that sub-machine.
When I return to diagram A then the symbol of the submachine has changed its size and furthermore it displays the sections of the sub-states.
That is an undesired side-effect. How can I avoid it?
Thanks.
Re: Suppress display of concurrent substates
« Reply #1 on: July 12, 2005, 05:13:51 am »
Hello.
Thanks.
JJ?,  You are quite right, it IS an undesired side-effect and it's probably a bug.  Formally report it as such.
You should be able to suppress anything that can be included within the sub-machine.  Not just Entry and Exit points.
