Author Topic: New RTF generator hangs on large document  (Read 2620 times)
colinc
« on: July 07, 2005, 05:57:02 pm »
I am trying to use the new documentation generator on my project.
It runs for a usually around an hour then hangs at ,usually the same, Use Case. The project consists purely of Use Cases with scenarios, requirements, busines process models and a small amount of component information. The only diagram types are analysis diagrams.
I have found it works if I generate for a smaller number of packages but then I loose the table of contents.
The document produced is relatatively long; about 400 pages of use cases/scenarios.
Is anyone having similar issues, or more importantly worked out anyway around it ?
Thanks,Colin
ea0804
Re: New RTF generator hangs on large document
« Reply #1 on: July 08, 2005, 01:24:01 am »
This a bug in the generator...
i'm producing 900 page reports and have this every day. You have to restart EA before generating such a big report...
The first generation works fine, a second try hangs and after aborting the second try, EA crashes on the 3rd try...
Oh, and dont create the report from a database...
Backup your files to a .EAP file first... This speeds up the entire generation process alot. (at least for me)
« Last Edit: July 08, 2005, 01:26:03 am by ea0804 »
colinc
« Reply #2 on: July 13, 2005, 08:36:23 pm »
Well done to the Sparx team; with 768 it takes about 15 minutes and works perfectly!
Colin
