Author Topic: Code Generation [COMMENTS]  (Read 4639 times)
moacsjr
« on: July 13, 2005, 05:40:41 am »
I´m experiencing some problems when regenerating some classes. In the generated code there are new coments each time I try to regenerate the code.
It seams to be a forward generation problem.
public class Contato extends Pessoa {
* INDICA SE É O CONTATO PRINCIPAL. PARA OPERAÇÕES ONDE O CONTATO NÃO FOR INFORMADO É UTILIZADO
* O CONTATO PRINCIPAL.
* INFORMADO É UTILIZADO O CONTATO PRINCIPAL.
private boolean principal;
* LISTA DE AREAS DE INTERESSES DO CONTATO
private Collection areasInteresse;
Re: Code Generation [COMMENTS]
« Reply #1 on: July 13, 2005, 03:33:47 pm »
I'm not able to replicate your problem.  Could you let us know what version and build of EA you are using?
Simon
golyshkin
« Reply #2 on: July 13, 2005, 07:59:14 pm »
I observed this too. For fix it u should remove all generated files and try generate it again
moacsjr
« Reply #3 on: July 14, 2005, 05:26:05 am »
yes, but if you couldn´t remove the files. If they has been filled with code and you are updating the classes. eg. add some new attributes.
Houston, I think we have a problem!
Moa.
moacsjr
« Reply #4 on: July 14, 2005, 05:37:26 am »
Simon
Just create a new class in a diagram and add 2 attributes to it with comments for each attributes. Generate the java files and open it. Generate it again and look the generated files, you will see that you have duplicated comments.
Moa.
« Reply #5 on: July 14, 2005, 03:30:22 pm »
Sorry, I still can't replicate it.  What build of EA are you using?  If it's not the latest, are you able to update it?
moacsjr
« Reply #6 on: July 15, 2005, 11:52:10 am »
I´m using EA 5.0 build 767
