Author Topic: Tagged Values + HTML Docu  (Read 2112 times)
Evelknevel
« on: July 21, 2005, 02:08:29 am »
Hello EA Users,
i have some questions
1. Is there a possibility to sort the tagged values? I can only sort them alphabetically but not by topic. I have many tagged values for each node. It is very complex to find the item needed, if I create a HTML-Documentation.
2. I think there is a bug, with the HTML Web Templates.
I would like to create a HTML Doku. It is not possible to change the <table>, where Tag, Value, and Note are displayed. I tried to delete the #Notes variable, but the Notes column did not disappear. If you look at the Template "Attributes" you can change the width of the table. Only with Tagged Values it is not possible.
3. I use our typical company-style-background in the HTML-Docu. It is not white. If a Note is empty there is no white border around the field. Only if a note is filled with a value, the white border around the Note field is displayed. It looks really bad.
I would be glad if you could help me.
Regards
Evelknevel
