Author Topic: Eclipse MDG Link Evaluation problems  (Read 4687 times)
thovden
« on: November 24, 2004, 02:19:16 am »
I downloaded the Eclipse MDG Link evaluation but it requests me for a license key. No 30 days evaluation... I've tried the MDG-link for VS.NET before - does that interfere with the MDG-link evaluation?
Torgeir
Rafael_Herrera
Re: Eclipse MDG Link Evaluation problems
« Reply #1 on: November 24, 2004, 02:28:11 am »
I tried to install the trial eclipse plug-in and was faced to the same problem. In my case, I never installed any plug-in before. So, I supose that the provided version is a full version instead of a trial.
I hope there will be soon a solution to this problem ;)
Raf
TomO
  • EA - Bridging the gap between Business and IT
    • Sparx Systems
« Reply #2 on: November 24, 2004, 02:31:41 pm »
G'day Guys,
Yes this is a known problem, and it has a simple fix. If you open up the "Register and Manage licenses keys" dialog under the Help menu and add the following key:
{7A75-1955-42df-98D1-C295}
It will give you a weird random message (ignore this), but it will enable you to trail the MDG for Eclipse.
« Last Edit: November 24, 2004, 02:34:12 pm by TomO »
thovden
« Reply #3 on: November 26, 2004, 03:05:48 am »
Thanks - that works :)
jsiebert
« Reply #4 on: February 03, 2005, 12:48:09 am »
Hi there,
today I tried to install the evaluation version of MDG link for Eclipse. When I enter the key from the post above EA keeps saying "Registration succeeded! Thank you for purchasing **** INVALID KEY ****." and doesn't add the key.
Does anybody have a clue on what could be wrong there?
Thanks!
Jens Siebert
xjecht
« Reply #5 on: July 21, 2005, 08:10:37 am »
I have the same problem - I can't run MDG Link for Eclipse, because I do not know the key - definitly version I have downloaded is not trial version.
I use EA version PE Build 767.
« Reply #6 on: July 21, 2005, 03:50:26 pm »
Hello Xjecht,
TomO posted the solution to this above.
