Author Topic: 2 associations betw. classes -- connectorDestRole?  (Read 4100 times)
Kaneda
« on: August 09, 2005, 02:44:54 pm »
Hi there,
I have two classes (Project and Firm), which are linked by two associations.
The reason is, that a Project can have multiple project members, but additionally up to one, not mandatory builder (its all about construction business stuff...).
The builder though can also be a regular project member at the same time.
A Firm on the other hand can be both projectmember and/or builder in multiple projects.
So I created both associations, where projectMember gets the {union} constraint and builder the {subset} constraint.
I altered the transformations, that if a destinationMulitplicity is of type  (0..*; *; 1..*), that a DataSet will be created within the destination class.
This is how I do it:
%if connectorDestMultiplicity != "0" or connectorDestMultiplicity != "1" or connectorDestMultiplicity != "0..1" %
         $attName=%connectorDestRole%+"sDS"
         $type="DataSet"
         %Property($attName,$type)%
         %Attribute__Prop_Attr($attName,$type)%
%endTemplate%
However, the DataSets often (not always?) ends up with the connectorDestRole of builder, not of projectMember.
Any way to control which connectorDestRole the template uses?
« Last Edit: August 09, 2005, 02:46:42 pm by Kaneda »
There are 10 types of people in this world. Those who understand binaries and those who don't...
Re: 2 associations betw. classes -- connectorDestR
« Reply #1 on: August 09, 2005, 03:38:46 pm »
There is also connectorSourceRole. (And connectorSourceMultiplicity etc.)
Simon
Kaneda
« Reply #2 on: August 10, 2005, 12:18:13 am »
Hi Simnon, thanks for the reply.
Though I have to admit, I think you misunderstood my question.:)
"builder" and "projectMember" are both roles a firm (target/destination) can have, they have nothing to do with the project (source).
The project-end of the associations (source) has no roles, as I can't think of any (and the association isn't navigable that direction anyway).
Additionally, both source associations have a multiplicity = *.
Is there maybe a way of doing sth like this( pseudo code):
if (connectors.Count > 1)
   get connector.DestRole where connecterConstraint == "union" ?
That way I could alter the template to always use the role of the union association, not any subset association.
Kaneda
« Reply #3 on: August 10, 2005, 02:24:08 am »
well, my initial problem is solved ("smart" as I am, I declared the target role pf projectMember private...).
But I still wonder if sth. like my pseudo code up there is possible?
