Author Topic: Column notes not showing???  (Read 3934 times)
Bill Egge
« on: August 16, 2005, 06:06:38 am »
If I add a note in a table column through the attributes dialog box it does not show up in the Notes section on the EA main window.  But if I add a note through the note section on the EA window then it shows up in the attributes dialog.
Whats up?
Re: Column notes not showing???
« Reply #1 on: August 16, 2005, 06:57:06 am »
Whats up?
Bill,
YMDVWFM (your mileage DOES vary - works for me...)
Seems to work fine both ways for me...  Have you made sure you highlighted the column on the diagram?  If you ddon't you'll get another note - typically the Table or another Column or Operation.
